Mask won't work
dima medlin
Mask won't work
on Feb 4, 2014 at 1:15:30 am
I'm just simply trying to mask half of my clip to make a transition. The bottom half of the clip just comes in from the left and the top half from the right. Although every time I try to mask half of it, the mask just doesn't apply. I try to change it to subtract, or inverted but the mask just does nothing. Am I doing something wrong?
Raphael Rogers
Re: Mask won't work
on Feb 4, 2014 at 4:21:06 am
Try precomposing the footage. Layer, pre-compose.
John Cuevas
Re: Mask won't work
on Feb 4, 2014 at 12:54:34 pm
Is the clip you want to mask, selected, did you accidentally lock the clip? Do you have any effects on the clip? Please post some screen grabs of your timeline and comp panel so we can better diagnose the problem.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
