Work around for mem problems
Jeff Corvetti
on Feb 3, 2014 at 2:20:44 am
Hello, I'm working on a project that has 4 compositions of roto brushing that are time stretched to run faster and then all brought into another composition to add effects. When I try to export this I get a memory error. I assume it's just too much my machine to handle. Is there a way I can segment this so the processing is done differently? Can I export the roto brushing into a separate file and just use it as footage? Is there a way to export so the background is gone (like what roto brushing does)?
Thanks for any help you can provide.
Todd Kopriva
Re: Work around for mem problems
on Feb 3, 2014 at 4:28:10 am
same answer that I gave here:
http://forums.adobe.com/thread/1396451
After Effects team blog
