Duik Problem - Updated PS File created an anomaly
Gerald Hapeman
on Feb 2, 2014 at 7:26:18 am
I created a run cycle - simple enough. Works perfectly. Since then, I had to adjust one of the arms in photoshop (shaved away with the eraser tool a bit of an axe blade). When I play the file back in AE, there is a weird anomaly of what appears to be bits and pieces of the arm I edited (but not where I erased) scattered on the arm, like it duplicated itself in bits and pieces. See picture. I tried to reload footage and that does nothing... I tried to erase them, but if I do, I must erase every frame, but even so, it leaves or punches holes onto the composition so that when the axe does pass through where I erased, it doesn't show... as if I erased. HELP!?
Gerald Hapeman
Re: Duik Problem - Updated PS File created an anomaly
on Feb 3, 2014 at 7:38:34 pm
Figured it out...
