Placing different cubes after each other
Tim de Klerk
on Jan 31, 2014 at 1:46:41 pm
Dear users,
I would like to ask for your help. I have made a 3d composition with multiple cubes on it. I want to orbit around these cubes. Unfortunately, I can see one cube trough another. It will not help to change the layer order, as I will be seeing the cubes from different perspectives.
How can I prevent the cubes to be seen trough each other?
Here is an example:
Kind regards,
Tim de Klerk
Roland R. Kahlenberg
Re: Placing different cubes after each other
on Feb 3, 2014 at 12:32:29 pm
I believe that your cubes were created in a precomp and then nested in a 'final' comp. Once you've nested the comp, switch on the Collapse Transformation switch so that 3D interaction between the cubes works as expected.
There are lots more info on working with 3D layers in AE here - http://helpx.adobe.com/after-effects/using/3d-layers.html#3d_layer_interact...
Cheers
RoRK
Latest AE Workshop - MoGraph Intensity - Shapes & Text
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
