Image size / format best practices
Bruce Gaber
on Jan 30, 2014 at 6:01:41 pm
OK, after my last totally arcane posting I have a truly newbie question.
I just loaded a 40 frame 16 bit PSD image sequence (thinking I might want to do some subtle color work). And then I began to wonder if I was setting myself up for a big performance hit re RAM preview and rendering. Is this the case? Would it be better practice to work out the details of the project with a JPG sequence and then only pull in the heavy duty files just before color correction and final rendering?
Thanks so much
Bruce
Photographer / Motion Graphics Artist
Vision Rising
vimeo.com/BodhiBruce
visionrising.com
Dance Without Reason
Roland R. Kahlenberg
Re: Image size / format best practices
on Jan 30, 2014 at 6:19:34 pm
With JPEG, your color work will be compromised. It's best to work with the same color fidelity as the final files. I suggest that you instead work with proxies, which are a smaller or lower resolution (pixel-wise) relative to the final files. Take a look at this COW Tutorial here - http://library.creativecow.net/articles/hamad_serge/proxies.php
Having said that, since you only have a small number of frames, you might as well just go ahead and work with the final files, from the very start. I doubt that your system will be greatly troubled by RAM previewing 40 frames. As and when required; when RAM Preview fails to render the entire Work Area, you can always reduce the comp resolution and zoom values.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
Bruce Gaber
on Jan 30, 2014 at 8:14:43 pm
Thank you very much. This is useful--and liberating--information.
Bruce
Vision Rising
visionrising.com
on Feb 3, 2014 at 3:35:04 pm
Bruce, I'm glad you found the information useful.
Cheers
RoRK
Latest AE Workshop - MoGraph Intensity - Shapes & Text
