Quicktime not found
paul dashwood
Quicktime not found
on Jan 29, 2014 at 7:09:36 am
Hi There, I have read all the posts I can find but none seem to solve my problem I get this message .
I cannot choose an output because of this
and then get this message
These is the versions I am using. Quicktime 10 and after effects 12
I would so appreciate any help as I'm becoming desperate.
Thank you so much
Paul
Doyle Lewis
Re: Quicktime not found
on Jan 29, 2014 at 5:14:19 pm
I actually just had the same problem two days ago. I did a full restart of my computer and then AE started recognizing QuickTime again. I had done a disk repair and cleared out a ton of temp files the day before that so I don't know if that had anything to do with it. Have you used Mac's disk utility recently?
Doyle Lewis, Assistant Videographer
thinkck.com
paul dashwood
on Jan 29, 2014 at 6:42:17 pm
Thanks Doyle,
2 days ago I had my mac serviced but I will have a look at clearing out old files - this is really frustrating
John Cuevas
on Jan 29, 2014 at 9:16:34 pm
I believe there are some issues with the new mac os, quicktime and AE. I believe the solution is to use QT7, but you might want to check around first.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
