problem in AE camera
yousef tannous
on Jan 23, 2014 at 7:02:03 pm
hi , i wish you could help me with this weird problem i encountered ! in my comp after i make a composition and want to add a camera , 3d effects like particular would animate in the first keyframe but as soon as i insert a new keyframe for the camera every 2d layer would animate regularly but 3d effects ( in my case particular) has'nt been affected!!
thanks in advance :)
Dave LaRonde
Re: problem in AE camera
on Jan 23, 2014 at 7:07:53 pm
Have you set Particular to use the Comp Camera?
Dave LaRonde
Promotion Producer
yousef tannous
on Jan 23, 2014 at 7:29:54 pm
Thank you for your prompt response, ive tested with particle world and and the same thing happend, I can change the general camera view , rotate, track z etc.. but when I click the stopwatch and insert a new keyframe camera animation wont affect the 3d effect.. so I can conclude that its not particular specific problem but a camera one.. any ideas ???
Sam Freeman
on Jan 23, 2014 at 8:48:01 pm
Do you have your disk cache enabled? If so try turning it off (preferences>media&disk cache>enable disk cache tickbox) and empty existing cache items.
Some 3D effects don't refresh the cache and show old frames rather than new...
yousef tannous
on Jan 23, 2014 at 10:07:20 pm
Thank you for your response, I tried that but it didnt solve the problem ..
Walter Soyka
on Jan 24, 2014 at 5:17:00 am
A couple of screenshots showing the problem would be helpful.
It's possible that your comp viewer is set to a custom view. If so, set it to Active Camera instead:
[image]
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
