Masking on multiple layers
Emily Allett
on Jan 22, 2014 at 10:52:57 am
Hiya.
I have seen this covered before on CC, however, not with the issue I am having.
I need to create a mask that covers all layers under the top layer.
I have tried to use an adjustment layer, but it just isnt working for me.
Basically, whenever I create a mask, it follows the items around, so its not a true mask. See the attached image for what I am trying to mask.
Hope someone can help. Its probably the easiest thing, but I just can't work it out.
Todd Kopriva
Re: Masking on multiple layers
on Jan 22, 2014 at 4:25:00 pm
You are in the process of being helped with this here:
http://forums.adobe.com/thread/1385612
After Effects team blog
Darby Edelen
on Jan 22, 2014 at 9:40:32 pm
The stencil and silhouette alpha blend modes are also good options. These would be applied to a solid layer above the layers you want to mask.
Darby Edelen
