Light shaft/beam work-arounds please.
Jon Price
on Jan 21, 2014 at 1:28:33 pm
A few things to note:
I working on an AE project whereby no plugins can be used. Please do not suggest the use of a 3D program to do this properly, I'm hoping for an AE work-around. Any help will be massively appreciated. Working in CS6. :)
I am aiming to demonstrate way light refracts through a prism (http://images.fineartamerica.com/images-medium-large/9-light-passing-through-prism-david-parker.jpg).
I have constructed a 3D prism by rotating squares and triangles - this exists in 3D space. I have set a spot light against the prism. However, I cannot see the origin of the light, not it's ray/beam of light. I understand this is just the way it works in AE, only displaying the surface reaction to the light, but I would like a solution if possible.
I have tried using 'beam' effect, but this does not appear to work within a 3D space (it flattens) and it doesn't point from a distant position, to the prism in the 3D space.
I would like to be able to animate the camera, from the flare of the beams source, travelling along and reaching the prism.
I'm not looking for hyper realism, just a nice diagrammatical way to show it.
Also, if anyone has any ideas how to best replicate the rainbow colours out the other side I would also be open to suggestions!
Thanks in advance!
Ridley Walker
Re: Light shaft/beam work-arounds please.
on Jan 21, 2014 at 5:40:24 pm
This may help. A script that simulates light volume and source that works in 3D.
http://petertorpey.com/tutorials/volume_light/
