Why RAM Preview 2x faster on Macbook Pro vs Desktop PC?
David Huettner
on Jan 19, 2014 at 11:25:48 pm
Hello everyone,
I RAM Previewed a few seconds of an AE CS6 project on a Desktop PC I recently had custom-built, and was distraught to discover it was twice as slow as previewing the exact clip on my Macbook Pro. The project involves simple 3D camera movements. Why might this be so, and can I tweak my PC settings to get more out of it?? I will greatly appreciate any feedback I can get...I'm still new to the Adobe world, and even newer to computer configuration. Thank you!
Desktop PC
16 GB RAM DDR3
Intel Core i7-4770K Haswell 3.5GHz
Asus Sabertooth Z87 motherboard
GTX770 2GD5 video card
Samsung 840 EVO SSD/1TB 7200 RPM HDD
Windows 7 Home Premium 64bit
Macbook Pro (August 2012)
8 GB RAM DDR3
2.3 GHz Intel Core i7
NVIDIA GeForce GT 650M 512 MB
OS X 10.9.1
AE Configuration for PC:
max disk cache size: 10 gb
11/16 gb RAM reserved for other apps
4/8 CPUs reserved for other apps
2GB RAM allocation per background CPU
render multiple frames simultaneously is checked
AE Configuration for MBP:
4/8 gb RAM reserved for other apps
1GB RAM allocation per background CPU
Thank you!!
Alex Gerulaitis
Re: Why RAM Preview 2x faster on Macbook Pro vs Desktop PC?
on Jan 20, 2014 at 2:02:56 am
Could you check your per-core CPU usage, memory usage on each system during RAM preview?
-- Alex Gerulaitis | Systems Engineer | DV411 - Los Angeles, CA
Walter Soyka
on Jan 20, 2014 at 3:23:12 am
The cache system in Ae CS6 and higher can play a major role in apparent RAM preview times. You should be sure to clear the disk and image caches before benchmarking.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Todd Kopriva
on Jan 20, 2014 at 7:53:39 am
Relevant to Walter's comment, the SSD in the laptop can make a huge difference.
Also, we don't know anything about your project, so it's unclear whether your multiprocessing settings are better suited for the composition being rendered on one computer or the other.
After Effects team blog
David Huettner
on Jan 20, 2014 at 8:30:48 am
Thank you all for your comments!
Alex: Would I check this through the Activity Monitor on Mac, and Task Manager on PC?
Walter: I made sure to clear the Disk caches on both systems right before RAM previewing.
Todd: My Macbook Pro has an HDD, not an SSD. My PC has both.
Here are a couple screenshots of the project, I hope it helps:
Text objects with Turbulent Noise effect, floating in space, with a .eps image as the ground, with a 3D one-node camera using depth of field, and 3D lights.
Thanks again,
David
Walter Soyka
on Jan 20, 2014 at 2:44:55 pm
[David Huettner] "AE Configuration for PC:
2GB RAM allocation per background CPU"
These settings leave only 5 GB of RAM available to Ae. Since you are asking for 2 GB of RAM per background CPU, you are only starting two instances of the renderer on your PC.
[David Huettner] "AE Configuration for MBP:
1GB RAM allocation per background CPU"
These settings leave 4 GB of RAM available to Ae. Since you are asking for 1 GB or RAM per background CPU, you can start four rendering instances -- twice as many as on the PC.
In my opinion, your reserved RAM on the PC is too high. You should reserve 4-6 GB of RAM for other processes. You may also lower your minimum RAM allocation per background CPU, as it doesn't seem like your comp is extremely RAM-intensive. If you see the comp failing over to the foreground renderer, then try bumping up the minimum RAM allocation per background CPU again.
Walter Soyka
David Huettner
on Jan 20, 2014 at 8:11:12 pm
Thank you, Walter!! I gave 12GB RAM to AE, 6 CPUs, with 2GB per CPU, and now it runs a LOT faster. I am very pleased :) Thank you everyone for your help!
