Fill layer with layer
Jurjen Versteeg
on Jan 17, 2014 at 2:46:25 pm
Hi there,
I want to to do a fairly simple thing, but can't seem to find the right solution.
I want to give 20 layers in my composition a fill of another layer.
Sort of the "texturize" effect, but without the lighting options.
Any ideas?
Thanks a lot!
I don't want to Luma/Alpha matte every layer, because I need to do a ton of them ;)
Roland R. Kahlenberg
Re: Fill layer with layer
on Jan 17, 2014 at 3:01:37 pm
Place the Fill layer at the top of your Timeline layer stack and switch on its Preserve Underlying Transparency switch - it's the T switch in the Modes section of the Timeline.
HTH
RoRK
AE MoGraph Intensity Workshop - Promo Video
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
Philip Bowser
on Jan 17, 2014 at 8:01:41 pm
Wow! I've never used this feature before! This is great. Thanks Roland.
Philip. Bowser
on Jan 18, 2014 at 1:09:24 am
It's quite useful for other uses well since the top layer only appears when there are non-transparent pixels on underlying layers.
Cheers
RoRK
Jurjen Versteeg
on Jan 20, 2014 at 12:24:08 pm
Hi Roland,
Thanks! Great function, but it does not quite what I'm looking for.
I want to texture to be on the layer itself. So when I rotate and position the layer, the texture should stick to it.
Any ideas? Thanks!
on Jan 21, 2014 at 12:58:39 am
Sounds like you need to parent the texture to the layer. Since there is more than one layer with the alpha channel, you can't use the method I proposed. I suggest that you look into using a regular Track Matte or the Set Matte effect, together with a parenting structure.
HTH
RoRK
