• | Composition Question
on Jan 16, 2014 at 10:02:23 pm |
No matter how I set my new composition settings all I create is a square comp. Any ideas?
TIA
• | Re: Composition Question on Jan 16, 2014 at 10:53:54 pm |
You may have stumbled onto a hidden feature in AE. ;-)
Just kidding! Tell us how you're creating the comps - post screen shots of the Comp Settings dialog window and the comp after you've created it.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
• | Re: Composition Question on Jan 16, 2014 at 11:36:45 pm |
Exactly, hit ctrl+k and tell us the width, height and pixel aspect ratio. Otherwise you've found an Easter egg!!
http://www.ardillamedia.com
• | Re: Composition Question on Jan 17, 2014 at 2:37:20 pm |
Thanks for the responses. (CS6)I've used the HDTV 29 preset initially. Then changed to NTSC DV Widescreen, PAL Widescreen. I've tried 8 or 9 different combinations with different pixel ratios. The project window gives the right dimensions (1920x1080)but in the comp window it's square.
I'm almost thinking I will have to re-install. Which being cloud based now can be a pain.
• | Re: Composition Question on Jan 17, 2014 at 3:17:12 pm |
I suggest that you delete your Prefs to see if it'll sort out your issue - it's much faster than re-installing. Also, don't forget to Sign Out (Help Menu) prior to uninstalling.
HTH
RoRK
• | Re: Composition Question on Jan 17, 2014 at 3:57:27 pm |
Deleting the pref's worked. Thank you for the help.
• | Re: Composition Question on Jan 17, 2014 at 5:56:10 pm |
Did the composition extend from edge to edge of the comp viewer?
Darby Edelen
• | Re: Composition Question on Jan 17, 2014 at 6:18:49 pm |
No it was just a square in the middle. Deleting the preferences worked. My prefs are pretty native so it wasn't a hassle.
