map zooming with same stroke size
Timo Rimo
on Jan 15, 2014 at 11:53:58 pm
Hi everybody,
I have a problem. I want to create a map zoom like known from Google maps. For this reason I created a large Illustrator file. The problem is that the stroke weight of the layer "stroke" (like streets at Google maps) has to keep the size until a specific zoom value although the camera is moving towards it.
Do you have clue how to create it? Here's a project folder with a part of my map and the AE project file. Furthermore you will find "3D Timeline 2 copy(CS5).aep" which uses an expression that keeps the size of the typography and the y height of the squares at the same size no matter what the camera does. I need something similar for my map right?
Thanks for any help! :) I really don't know how to start :(
Here you will find the project files:
/// https://dl.dropboxusercontent.com/u/15159134/140115_map%20sample.zip
