Looking for a way to approach a transition/fade substitute
Ryan Shea
on Jan 11, 2014 at 6:38:18 am
Hi All:
I'm currently working on a video infographic of sorts, which includes a globe. In the previous draft of the animation, I had a simple CC sphere applied to the image, which gave me what I wanted. I then used a simple opacity fade to change the color of the globe.
I'm wondering what I could use to make the transition between colors more dramatic - when I used a fade, the color change is almost unnoticable. I imagine that there could be a more interesting way to present that the globe is changing.
This is my current animation that I have (the globe changes from a blue to a red-ish): http://i.imgur.com/yOdortD.gif
Thanks in advance!
John Cuevas
Re: Looking for a way to approach a transition/fade substitute
on Jan 11, 2014 at 2:09:11 pm
Well if you precomp your map-you could do some transitions in the precomp-then apply CC sphere to that precomp. A wipe might be a little bit more dramatic, or maybe even a CC Light Wipe.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
