trying to animate Bubbles or Particles alone a path in a tube??
Mark Linthicum
on Jan 10, 2014 at 5:24:47 pm
Hi All,
I know I have seen this done before, i am trying to animate Bubbles or Particles alone a path (in a tube),
The particles need to move along a curved path and not go outside the constrains of a the tube.
If anyone can point me in the direction of how to do this with the stock AE plugins or if it is not possible what 3rd party plugs i need it would be greatly appreciated.
Thanks Mark
Thanks, Mark
Bobby Yarsulik
Re: trying to animate Bubbles or Particles alone a path in a tube??
on Jan 10, 2014 at 6:39:30 pm
Was doing some searching because I don't personally know how to achieve this, but it looks like someone may have included a project file in this post on Video Copilot that may achieve what you are looking for!
http://www.videocopilot.net/forum/viewtopic.php?f=4&t=40384
edit: Although it looks like he is using particular, so I'm not sure if that is required or if you can use the stock particle plugins or not!
Mark Linthicum
on Jan 11, 2014 at 8:20:10 pm
Thanks Bobby Yarsulik!
Thanks, Mark
Roland R. Kahlenberg
on Jan 12, 2014 at 4:58:34 am
AE's built-in Foam plugin will do this. More info here - http://helpx.adobe.com/en/after-effects/using/simulation-effects.html#foam_....
Pay particular attention to the use of a Flow Map which dictates the confines of particles created by Foam.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
