Mask is feathering, but feather = 0
Dino Juarez
on Jan 6, 2014 at 5:31:46 pm
I have a video layer as my bottom layer. I duplicated that layer and applied a Fast Blur to it. Then I drew a rectangular mask on the blurred layer. My Mask Feather setting is 0, but the mask is feathering the edge. So instead of a hard edged mask around my blurred video layer, it is a soft feathered edge. I want to avoid using a track matte if possible. I thought a mask would give me the effect I want, but mayber masks can't crop a blur with a crisp solid edge. Anyone out there have any suggestions?
Thanks.
Dave LaRonde
Re: Mask is feathering, but feather = 0
on Jan 6, 2014 at 6:02:24 pm
Precomp the blurred footage, then make a mask on the precomp?
Dave LaRonde
Promotion Producer
Dino Juarez
on Jan 6, 2014 at 6:06:11 pm
I tried to precomp but that doesn't work either. I just think masks can't "mask" a blur. I guess I have to use a track matte.
Dino Juarez
on Jan 6, 2014 at 6:08:23 pm
Actually, I misunderstood your suggestion. So the precomping DOES work. I put the blur in the PRECOMP layer, then applied the mask in the second comp and that did the trick. Thanks.
Ridley Walker
on Jan 6, 2014 at 6:06:14 pm
After Effects default is to render Masks before Effects. So the Mask is applied *then* the blur.
To fix this remove the mask from the blurred layer and pre-compose it, then apply the Mask to the pre-comp.
@Dave, ya beat me to it. Hope you're not freezing today in the Polar Vortex.
