How to mask a 3D layer's casted shadows?
Jordan Flower
on Jan 5, 2014 at 12:48:07 am
So if you look at the attached image, you should be able to get an idea of what I'm doing. I want the text and its shadows to appear like they're behind the guy on the bike as he coasts by. I have no problem masking the text, but the shadow still seems to come through (you can see the shadow on the guy's tan jacket). How do I also mask the shadow so it appears behind the guy?
Roland R. Kahlenberg
Re: How to mask a 3D layer's casted shadows?
on Jan 5, 2014 at 1:21:16 am
I believe that your "floor" layer contains the shadow. Hence use the same mask/matte that you use for the main text, for the 'shadow layer'.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
Jordan Flower
on Jan 5, 2014 at 3:28:09 am
Oh right, of course! I'll just keyframe the mask around the guy as a matte on the text layer, and then just duplicate and apply to the shadow layer. Not sure why I didn't make that connection before coming here. Thanks!
Darby Edelen
on Jan 5, 2014 at 6:14:42 am
An alternative I would suggest is to duplicate your background plate, place it above all the layers and mask the foreground subject as needed to block the text/shadow. This way if you add more background layers you won't end up with another duplicated matte for every one.
Darby Edelen
Jordan Flower
on Jan 6, 2014 at 8:50:18 pm
Nice call. I'm doing this on additional comps now.
