Layer Bar Size Import to Project
Gerald Hapeman
on Jan 3, 2014 at 8:44:50 pm
I know it seems rather AE101, but I didn't really know the correct terminology other than what I put in the subject line and couldn't find my answer. When I import image files into a project, I would like that file size (as in the layer bars that stretch out) to match in size with other files I already placed in the project that having to manually resize and adjust them every time. Is there a shortcut for this?
John Cuevas
Re: Layer Bar Size Import to Project
on Jan 3, 2014 at 8:55:43 pm
There is no auto resize upon import for images. When I have images that different sizes, I create an action in photoshop to resize and crop so everything will match up. Then run a Batch Automate on the folder with the images(making sure I save in a different location).
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Walter Soyka
on Jan 3, 2014 at 9:15:40 pm
[Gerald Hapeman] "When I import image files into a project, I would like that file size (as in the layer bars that stretch out) to match in size with other files I already placed in the project that having to manually resize and adjust them every time. Is there a shortcut for this?"
You're talking about layer duration, right?
You might like this:
http://aescripts.com/trim-to-layer-above-and-trim-to-layer-below/
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
John Cuevas
on Jan 3, 2014 at 9:18:21 pm
Duration---that makes a lot more sense. Doh!
Thinkck.com
Gerald Hapeman
on Jan 3, 2014 at 9:42:30 pm
Yes. Duration... Sad me... I just couldn't remember the basic terminology. Thanks both! I'll try that script!
Gary Milligan
on Jan 4, 2014 at 6:46:05 pm
No scripting necessary… it's in your preferences settings (Import). Select "Length of Composition".
HTH
Gary
Gerald Hapeman
on Jan 5, 2014 at 12:31:58 am
Yup!! Thanks Gary! That's it!
