Frame Rate for Motion Graphics
Zach Youngblood
on Jan 2, 2014 at 8:14:28 pm
What frame rate would be recommended for 2d motion graphics created in AE? Im assuming that 30 or 60fps would be better for objects in fast motion. 24fps looks a bit jittery. Im using imported vector shapes.
John Cuevas
Re: Frame Rate for Motion Graphics
on Jan 3, 2014 at 1:32:40 am
What's your deliverable(ie where will it be seen). For web work, 30FPS, for broadcast I use either 720 60p.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Zach Youngblood
on Jan 3, 2014 at 2:52:48 pm
Deliverables are primarily for web.
John Cuevas
on Jan 3, 2014 at 5:25:20 pm
Work in 30FPS, working in 60FPS and you will just be rendering twice as many frames and that will never be played back.
Thinkck.com
