RAM previews won't show full quality.
JP Pelc
on Jan 2, 2014 at 4:29:05 pm
Recently when I try to do a RAM preview AE will only play it back at about 1/4 quality. I have the resolution selected to full in the Comp window and it shows the comp full quality when still, but RAM preview is still low quality. Interestingly enough if I hit spacebar, it will playback at full quality, just not in RAM preview. I'm sure it's just a setting I need to change but I have played around with settings for adaptive resolution limit, viewer quality, disk cache, video preview, and multiprocessing, all to no avail. Any ideas?
After Effects CC 12.1.0.168
OS X 10.8.4
3.4 GHz Intel Core i7
8 GB 1600 MHz DDR3
NVIDIA GeForce GTX 680MX 2048 MB
Walter Soyka
Re: RAM previews won't show full quality.
on Jan 2, 2014 at 5:14:34 pm
Look in the Preview panel. You have the option to set custom resolutions (separate from the viewer's settings) for RAM preview and for Shift-RAM preview.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Sam Lanes
on Jan 2, 2014 at 6:03:52 pm
Funnily enough, I recently wrote a blog post which goes through the settings for the RAM Preview function which may help:
http://www.aefromscratch.com/2013/12/30/working-with-audio-in-after-effects...
JP Pelc
on Jan 3, 2014 at 3:16:29 pm
Thank you Walter!! I knew it had to be a simple solution and I felt like a n00b not being able to figure it out. Much appreciated!
OS X 10.8.4
8 GB 1600 MHz DDR3
