How to use effect on a tracked corner pin layer ?
vasdg agsdgasdg
on Dec 29, 2013 at 10:03:36 am
Hello, i am doing a project where i track a picture frame in mocha and freeze frame myself.
i am looking to shatter this inside frame. how can i get the shatter effects to be only the the tracked corner pin frame ?
i have tried placing it inside a comp with the layer, but then the pieces that break dissapair as soon as they hit the end of the frame and not the main comp.
i tried placing the same corner pin tracking data before the shatter effect, but that crashed AE.
i also tried a CC Power pin method but with no result.
does anyone have any idea's or tips on how to accomplish this ?
cheers
John Cuevas
Re: How to use effect on a tracked corner pin layer ?
on Dec 29, 2013 at 1:58:58 pm
After you corner pin the layer, precomp it(move all attributes into the precomp) and shatter the precomp.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
