After Effects BMCC - Import
Jim Sandstén
on Dec 24, 2013 at 7:33:41 pm
Hey guys, I would like to start with apologizing for any bad English (I'm from sweden)
Now to my problem, I work with a BMCC 2.5 camera and with After Effects CC in post
I'm trying to import a bunch of sequences into AE and I don't get the option to create a Sequence from the .DNG files (pic)
Now I have to enter each folder (sequence) every time I want to import a sequence and do this over and over again
(i can only import 1 folder each import so it takes a huge amout of time)
and when i try and drag and drop from Finder into AE it says
Thanks in advance and merry christmas to you all!
Erik Waluska
Re: After Effects BMCC - Import
on Dec 24, 2013 at 11:24:15 pm
Hey Jim, You might check out this thread, and then check out the immigration script that Walter recommended.
Erik Waluska
EAWmedia
Todd Kopriva
on Dec 25, 2013 at 3:35:45 am
Be sure that you don't have the audio files selected when you're trying to import an image sequence. That appears to be your problem.
After Effects team blog
Jim Sandstén
on Dec 25, 2013 at 1:29:45 pm
The multiple import has worked with audio a while ago, and removing all the audio files in the folders is also time consuming but thanks for the advise
