Pro import After effect CS6 - One (or more) VIDEO footage are missing (5027::12)
Diego Centurión
on Dec 24, 2013 at 3:55:02 pm
Hi friends, i'm trying to import a AAF file into Adobe after effect using Pro Import After effects. I have the aaf (wich is a sequence exported from Avid media composer)in a external disk, then i copy that file in the computer where i use After Effects and import it with Pro import AE.The sequence is imported but non of the video are found.It saids: One (or more) VIDEO footage are missing (5027::12).
By the way i also copied the original footage in the computer.
I will be realy grateful if someone can help me understand what im doing wrong.
Greetings =)
