AfterFX Character Rig slider expression link...
Craig Reeves
on Dec 23, 2013 at 11:17:29 am
Hello everyone,
I have been creating a character linked to a number of ai files.
I have layers that make up different parts of the head, in different angles - in different compositions.
My question:
Is there an expression that when linked to a 'slider' will turn the opacity of a pre comp on, then off when that value is altered. for e.g..
Head FRONT on only > in-between slider value 0-10
Head LEFT on only > in-between slider value 11-20
Head BACK on only > in-between slider value 21-30
etc. etc...
Thanks in advance!
Walter Soyka
Re: AfterFX Character Rig slider expression link...
on Dec 23, 2013 at 3:46:44 pm
[Craig Reeves] "Is there an expression that when linked to a 'slider' will turn the opacity of a pre comp on, then off when that value is altered. for e.g..
Head BACK on only > in-between slider value 21-30"
Alt-click the Opacity stopwatch for the layer and enter the following expression:
slider = thisComp.layer("CONTROLLER").effect("SLIDER")("Slider");
if ((slider > 0) && (slider <= 10)) 100 else 0;
Modify the ranges for the test for each layer.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Craig Reeves
on Dec 23, 2013 at 5:26:03 pm
Thank you thank you thank you! :D
