Text Chatter
Richard Kratt
Text Chatter
on Dec 20, 2013 at 6:17:51 pm
I am doing a small scale up of black text files I received in Illustrator. They are in a precomp and scaled up to 418% and I have "collapsed transformations." In the main comp I'm scaling the text from 100 to 110% and there is a chatter. How do I get rid of the chatter? I'm at a loss.
Thank you so much in advance.
Roland R. Kahlenberg
Re: Text Chatter
on Dec 20, 2013 at 7:59:45 pm
When ever possible, do all your scaling in a single comp. In your case, do it in the precomp.
I can't visualize "chattering" on text as such a description is not usually ascribed to text. But try the procedure above and see if it solves your issue. Otherwise, provide a sample movie and include details of all the properties that you have changed/keyframed.
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
© 2018 All Rights Reserved
