How can I make a Prores 4444 video from After Effects?
Kim Tyler
on Dec 19, 2013 at 7:33:04 pm
Sorry to post one of these types of questions, but I'm up against it and I need to deliver some renders I've done in AE in prores 4444 format in order to be graded.
The problem is, I've never had to do this before and have no idea how to do it. Web searches are coming up with nothing useful. I can't seem to do it from adobe media encoder even with the prores plugins (only have 422) and I think I might be able to do it with final cut but I don't know how.
Argh! Can anyone help?
Dave LaRonde
Re: How can I make a Prores 4444 video from After Effects?
on Dec 19, 2013 at 10:17:51 pm
You need to have Final Cut Pro. It gives you access to Quicktime Pro, which in turn gives you the ability to read & write the Apple's ProRes family of codecs... one of which is ProRes 4444.
Now, if you happen to be on a Windows Box, that puts you in a bit of a pickle. Anybody know of Windows-based Read-Write ProRes Codecs?
Dave LaRonde
Promotion Producer
EricBowen
on Dec 20, 2013 at 12:22:07 am
http://www.cinemartin.com/cinec/
Eric-ADK
Tech Manager
support@adkvideoediting.com
Kim Tyler
on Dec 21, 2013 at 1:15:52 pm
Thanks Dave. I ended up exporting from FCP in the end, works fine.
On a side note, I discovered AE can output 4444, under quicktime and then in options. However I had issues with the alpha matte on it, it didn't come out as nicely as the FCP rendered file.
Patryk Ming
on May 5, 2016 at 9:04:22 am
Hi. Are there any new information about using ProRes 4444 through After Effects on windows ?
