PF Track Image Distortion to After Effects
stephen turcotte
on Dec 16, 2013 at 3:19:03 pm
PF Track allows for Lens Distortion Export as a .pfb file (PF Barrel file).
Is there a way to input this or the data into AE? I have tried a few plugins and I can totally eye-ball it, but I'd much rather use the actual data from PF Track to assure that I'm applying the same distortion to the background plate.
The reason why I don't undistort in After Effects before tracking is because PF Track has a tool for this and tends to give more accurate results- giving the ability to refine and adjust as your solving the shot.
Any input would be great!
Oliver Zuniga
Re: PF Track Image Distortion to After Effects
on Jul 26, 2016 at 9:06:53 pm
Looking for an answer to this same thing.
stephen turcotte
on Jul 27, 2016 at 12:31:40 am
I think the best solution is to export the plate right from PF Track. In the exports node, there should be an option fo you to export the image sequence.
