Problem with adding Knoll Light Factory to solid, the background does not turn transparent as shown in tutorials with older version of KLF
Von Betelgeuse
on Dec 14, 2013 at 5:23:11 pm
I've got a problem using Knoll Light Factory, when I drag it onto a new solid the background does not turn transparent, it does when adding particular and has been shown to turn transparent in older tutorials.
I need a Knoll Light to stay in position on a separate transparent layer, how should I go about doing this? :/
Mike Zimbard
Re: Problem with adding Knoll Light Factory to solid, the background does not turn transparent as shown in tutorials with older version of KLF
on Dec 14, 2013 at 6:40:25 pm
This did change in more recent versions of knoll. You now have to activate the unmult setting for the plug-in. Open the "rendering" tab and then click the checkbox next to unmult. You should see the background drop away.
Mike Zimbard
on Dec 14, 2013 at 6:40:41 pm
Joseph W. Bourke
on Dec 14, 2013 at 8:46:52 pm
I have always been most pleased with "lighting" effects, including Knoll and Optical Flares, when I create the effect on a black solid, and then composite in Add mode. This adds the values of the brighter pixels to the underlying layers, giving a more convincing, brighter flare.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
