29.976 frame slide with timers
Federico Ponce
on Dec 13, 2013 at 10:47:20 pm
HI greetings,
We are working with timers. Matching AE timers to burned in footage timecode. The footage is 29.97 and we have noticed that every 5 seconds our timers skip 3 frames. We are using Dan Ebberts, timer expression but we have also tried the default after effects timer with no positive results.
Can anyone provide a solution to this? Thank you !
Dave LaRonde
Re: 29.976 frame slide with timers
on Dec 13, 2013 at 11:32:48 pm
What is the frame rate of your composition?
Dave LaRonde
Promotion Producer
Federico Ponce
on Dec 13, 2013 at 11:34:44 pm
Hi Dave,
Thanks for the quick reply. The comp is 29.976 and we have tried interpreting the footage with and without drop frame.
Dave LaRonde
on Dec 13, 2013 at 11:52:21 pm
29.976 is not a valid frame rate in NTSC. If you are trying to give 29.97 footage the NTSC film frame rate of 23.976, I don't recommed simply putting it into an AE comp. You will get an uneven frame cadence.
You will have to do a frame rate CONVERSION, which is not the the same as conforming footage in AE's Interpret Footage settings. To do the conversion in AE, I recommend using Twixtor.
And also please note that you will NOT get a direct correspondence between frames, but if you do the frame rate conversion properly, the duration of the footage will not change from the original 29.97 footage.
Dave LaRonde
Promotion Producer
