newbie -- add time
Richard Doyle
newbie -- add time
on Dec 12, 2013 at 3:43:41 pm
Say you've got a series of elements that appear on screen for two seconds, and after the fact you realize that one right in the middle would work better if it was three seconds. Adding the time to that element is easy enough, but now everything following it is off by 1 second.
Is there an easy way to shift everything after a certain point over?
John Cuevas
Re: newbie -- add time
on Dec 12, 2013 at 5:31:40 pm
Select all the layers you need to move, move the CTI(current time indicator) 1 second forward from the first element, hold down shift and move them.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
