Scale Mask to distance between nulls
Michael Neumann
on Dec 12, 2013 at 6:01:03 am
I am not very skilled when it comes to After effects and I now ran into a small problem:
For now the position of the (Plexus) circle between her hands is calculated with an expression.
I was wondering if there is an expression I can use to let the circle get scaled by the measured distance between the two nulls. Right now everything is keyframed manually and it looks kind of cheesy.
Can someone help me with that?
John Cuevas
Re: Scale Mask to distance between nulls
on Dec 12, 2013 at 2:40:05 pm
You might try the Expression Forum, someone might have a way of working it out for you. The guys there are just incredible at figuring this stuff out.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Michael Neumann
on Dec 12, 2013 at 11:46:04 pm
I reposted it to AE Expressions. So this entry can be deleted pls.
