Warp stabilizer stalls analyzing
bart stevens
on Dec 10, 2013 at 5:08:43 pm
Does anyone know if there is a limitation with the warp stabilizer that it can only analyze one clip at a time?
If I analyze multiple clips in a single composition, they seem to stall in that stage?
mathew fuller
Re: Warp stabilizer stalls analyzing
on Dec 10, 2013 at 5:22:07 pm
Then don't do multiple clips in one comp.
My Work:
http://www.morecompletefx.com
bart stevens
on Dec 10, 2013 at 6:09:54 pm
Yes, that is one solution...
My purpose in posting the question is to try get more information.
I didn't see any documentation regarding this limitation, and have a lot of clips that could use some stabilization.
I've read on another thread that there is no "batch mode", but I wouldn't define analyzing multiple clips simultaneously as batch mode.
Todd Kopriva
on Dec 10, 2013 at 6:48:06 pm
What version are you using?
After Effects CC (12.1) made the Warp Stabilizer multi-threaded and much faster. It can now handle multiple simultaneous jobs:
http://blogs.adobe.com/aftereffects/2013/09/after-effects-cc-12-1-whats-new...
After Effects team blog
bart stevens
on Dec 10, 2013 at 7:31:40 pm
Hmmm... yes that's the version I'm using...
It seems like I'll set it to analyze, it analyzes for a while, but then quits.
So when I return to the clip, I see the blue bar in the middle saying -Click analyze to begin.
Ram and CPU loads are high but well below maximum.
Roland R. Kahlenberg
on Dec 11, 2013 at 11:54:20 am
[Todd Kopriva] "It can now handle multiple simultaneous jobs:"
Hi Todd, multiple jobs/clips on a single timeline OR individual clips on multiple timelines? I've always thought it was the latter and not the former.
Bestest
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
Todd Kopriva
on Dec 11, 2013 at 4:33:03 pm
The Warp Stabilizer effect can analyze footage in the background that is used in different compositions.
bart stevens
on Dec 11, 2013 at 10:30:01 pm
Thanks for the feedback,
Sounds like results will be better when using the effect in different compositions vs. multiple clips in different compositions.
Thanks again
on Dec 12, 2013 at 1:01:09 am
[bart stevens] "Sounds like results will be better when using the effect in different compositions vs. multiple clips in different compositions."
Bart, I believe you meant to write, "results will be better when using the effect on a single clip vs. multiple clips in a single composition." OR use WS VFX only on single clips. FWIW, it's the same thing with the 3D Camera Tracker.
HTH
RoRK
