CS6 problem with image sequence names.
Navarro Parker
on Nov 22, 2013 at 7:11:25 pm
I've run into a problem with image sequences named the Maya way: filename_vn.nnnn.EXT
If I have an image sequence named rollercoaster v6.nnnn.exr, and I don't pick the first 0000 frame (like I pick any random frame in-between the first and last), AE returns an error that it can't find "rollercoaster_v6.0.exr" I only get this problem with periods between the filename and image number. Using a space, hyphen, underscore
I've also found that AE is really slow importing image sequences if there isn't a separator between the filename and number. For example: rollercoaster0000.exr takes much longer to import than roller coaster_0000.exr or rollercoaster 0000.exr
Is this a bug? Does this still exist in CC?
© 2018 All Rights Reserved
