CC Particle World Not Keyframing
Lauren Samara
on Nov 20, 2013 at 10:47:16 pm
Hi, I'm new to this site and I've looked for an answer everywhere!
So my issue is that I created fire using the cc particle world effect. I wanted to keyframe the position so it looked like it was moving around, but when I played it back, it didn't move.The coordinates changed, but the actual fire in the comp didn't move.
After I tried to search for an answer and failed, I moved on to another method of moving the entire layer...not the point though! lol
So next I wanted to keyframe the birthrate....but that didn't do anything either! I wanted to try to make it look like the fire is building so I thought I would try starting the birth rate low, and then increasing it. But if I wanted to have it at, let's say, start at 0 and then work up to 2, then it just doesn't show up - it just appears as if the birthrate is at 0 the entire time. But when I scroll through the timeline and see if the birthrate number changes, the number changes but there isn't a change visible in the comp.
So basically the issue is that the keyframes don't seem to be having any visible change in the comp. I created a fire using CC particle world and I want to keyframe the position and the birthrate.
I hope I'm making sense...if you need to know any more information in order to assist me, feel free to ask. This is driving me crazy!
© 2018 All Rights Reserved
