Freeze frame expression?
Stefan Mandersloot
on Nov 19, 2013 at 5:50:59 pm
Hi all,
I've got a question about an expression that can help me 'batch' some files. What I need is an expression that can double odd numbered frames. So if my first 4 frames are A B C D, what I'd like the expression to make of it is A A B C C D, and so on for all frames... Could someone help me with that? I've done a Google search already, but I actually don't really know what to look for...
Thanks in advance!
Stefan
Dave LaRonde
Re: Freeze frame expression?
on Nov 19, 2013 at 7:22:11 pm
How about if you open the Interpret Footage settings for the layer and divide the frame rate by one-half? It does the same thing.
Dave LaRonde
Promotion Producer
Stefan Mandersloot
on Nov 25, 2013 at 10:50:12 am
Thanks a lot! Exactly what I was looking for, such a simple solution!
Kevin Camp
on Nov 19, 2013 at 7:22:40 pm
i haven't tried this, but i think if you time stretch the footage 150% and turn off frame blending it will do what you are looking for.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Stefan Mandersloot
on Nov 25, 2013 at 10:53:49 am
Hi Kevin, thank you for your suggestion! Your method worked as well, so now I've got two to choose from :-). Thanks!
Stefan
