What the heck is a "floating" licence?
Gregory Cowell
on Nov 17, 2013 at 6:47:48 am
I suppose it'd be fair to say that if I have to ask this question, I really shouldn't be buying this software.... but forging ahead nevertheless....
I was interested in buying the 3D Camera Tracker from The Foundry. I have After Effects CS5, and I'm told it will work fine in it. So, I go to The Foundry and check out the options and decide to go ahead and buy it.
When I get to the "Buy" options page, I see there's several of them. I'm presented with the choice of a "node-locked", "Floating", or "render" licence. Being an ignoramus, I have absolutely no idea what this means! All I want to do is buy a piece of software and plug it into After Effects, and be on my way...
Can anyone clue me in, please? Thank you.
Greg.
Morten Ranmar
Re: What the heck is a "floating" licence?
on Nov 17, 2013 at 9:28:57 am
Node-locked means it onlyregisters for one computer. Floating means you can register in or out on different computers, much like Adobe CC.
- No Parking Production -
2 x Finalcut Studio3, 2 x Prod. bundle CS6, 2 x MacPro, 2 x ioHD, Ethernet File Server w. X-Raid.... and FCPX on trial
Gregory Cowell
on Nov 17, 2013 at 11:24:30 am
Ah. So node locked is the way to go for an amateur who's only using one computer and a few applications, to do video.
Thanks, Morten.
Todd Kopriva
on Nov 17, 2013 at 5:29:05 pm
I'm curious about why you'd be buying the Camera Tracker plug-in rather than upgrading to After Effects CS6 for less money and using the 3D Camera Tracker built into After Effects CS6.
After Effects team blog
Darby Edelen
on Nov 17, 2013 at 5:46:01 pm
[Todd Kopriva] "I'm curious about why you'd be buying the Camera Tracker plug-in rather than upgrading to After Effects CS6 for less money and using the 3D Camera Tracker built into After Effects CS6."
The Foundry's Camera Tracker is better :) Whether it's worth the price or not is another question.
If performing camera tracks is something that you'll be doing a lot, you need flexibility for improving solves and you have the money to buy it then even with CS6 or CC I'd recommend The Foundry's plug-in.
Darby Edelen
Darby Edelen
on Nov 17, 2013 at 5:47:49 pm
One not so subtle distinction from CC in the case of The Foundry: you need to have a machine dedicated as the license server. That machine needs to be accessible via network from any computer that will need a license. If you don't have someone to manage a license server then that can quickly become a PITA.
Darby Edelen
Morten Ranmar
on Nov 17, 2013 at 6:33:06 pm
License server is only necessary for floating license, but could reside on any machine on the network.
Francis Battaglia
on Jul 3, 2014 at 5:10:16 am
Is there an option with node-locked to decommission one machine for use on another newer (if buying a newer machine, etc)?
Morten Ranmar
on Jul 3, 2014 at 7:29:24 am
Nodelocked uses a software key that is locked to a certain machine ( reads its hardware serial number) and can only be changed by contacting the vendor
Adobe CC, 3 x MacPro, 3 x MbP, Ethernet File Server w. Areca ThunderRaid 8.... and FCPX on trial
