After effects - how to make NOT THE EMITTER but the PARTICLES follow the path - ANTS TRAIL
mark ferix
on Nov 14, 2013 at 12:32:07 pm
hi I have been looking everywhere and all I found about paricles following the path is that in fact emiter follows the path ans leaves the particle behind
What I am after is something oposite - a particle emiter is stationary but the particles follow the path - emagine ants following each other from and to the anthill,
adding additional features like faster movement in parts of the path would be a bonus,
Anyone with the idea please help.
Many thnaks
M
Todd Kopriva
Re: After effects - how to make NOT THE EMITTER but the PARTICLES follow the path - ANTS TRAIL
on Nov 14, 2013 at 3:27:57 pm
When I've needed to do this for simple vector graphics, I've used the text animation features and had characters follow a path. Because you can get symbol / wingding fonts with a lot of different graphics elements, this turns the text features into a more general vector graphics animation feature.
After Effects team blog
Matthew Childs
on Nov 14, 2013 at 4:30:01 pm
Hey Mark.
This is pretty simple to do with Trapcode Particular; What particle engine are you using?
In Particular, you animate a light with the name "Motion Path 1"
Under Physics, Air, Motion path, change it from "Off" to "1"
mark ferix
on Nov 20, 2013 at 10:52:19 am
hi any chance for more detailed instructions please, I have tried for a few days now but obviusly I am missing the trick,
Many thanks,
mark ferix
on Nov 20, 2013 at 11:22:27 am
many thnaks found it!
http://www.redgiant.com/videos/quicktips/item/197/
Matthew Childs
on Nov 20, 2013 at 3:11:25 pm
Glad you were able to figure it out. Let me know if you run into trouble!
-Matt
mark ferix
on Nov 18, 2013 at 9:49:33 am
thanks gents,
As i am a true rookie here would you be able to reply in more details how to do it, please?
Thanks in advance,
M
