Recreating a thunder's LIGHT
Michele Poggi
on Nov 12, 2013 at 4:45:08 pm
Hi guys, I have to do a pretty nasty shot featuring a lightning... The thing is: it is out of shot. The lightning itself will be only heard and I have the clip showing the side of a palace with some trees. I have to create the light blast.
I'm worried since I'm not sure how to do it, do you have any experience or hint?
"Freelance Post-Producer"
Editor Video
Graphic Designer
Digital Compositor
Mail: snm.poggi@gmail.com
Mobile: +39 3349129191
Skype: sabakunomaiku
John Cuevas
Re: Recreating a thunder's LIGHT
on Nov 12, 2013 at 5:35:36 pm
Aharon Rabinowitz did a pretty good tutorial on weather replacement(creating a storm) where he creates some onscreen distant lighting, you might find it useful. Weather Replacement
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Michele Poggi
Re: creating a thunder's LIGHT
on Nov 12, 2013 at 6:55:13 pm
Thank you, I'll check that out! The issue is I'll have to create the light the thunder creates, not the thunder itself. (But I have to in another shot so thanks ;])
Editor Video
Graphic Designer
Digital Compositor
Dave LaRonde
on Nov 12, 2013 at 5:52:07 pm
I presume you will only see the light from the lightning falling on the building. You will need to pick a point light source, estimate the direction of the shadows, and animate from there.
I've done this before, but I had the luxury of having planned out the effect in advance. I was able to re-create the shadows with the help of two very large strobe lights. It worked well.
Dave LaRonde
Promotion Producer
Michele Poggi
on Nov 12, 2013 at 8:28:19 pm
I'd love to hear more. :) Thank you for the reply.
So.. My shot is of course a 2D movie. I also sadly have trees in front of the buildingm but even more than the shadows I'm unsure about how to do the light itself on After. I can't believe I'll have to play with levels and white solids, and most of all.. It's a thunder, so it will be fast as a gunshot.
I'm probably missing what to do frame by frame to do the illusion though...
Editor Video
Graphic Designer
Digital Compositor
Tudor "Ted" Jelescu
on Nov 13, 2013 at 7:37:57 am
It always helps if you post the clip - more ideas can come that way.
Tudor "Ted" Jelescu
Senior VFX Artist
Michele Poggi
on Nov 13, 2013 at 8:56:43 am
Sadly I can't, there's we can call it a NDA.
Editor Video
Graphic Designer
Digital Compositor
