Specific Video Breakup Effect
Robert Gotham
on Nov 9, 2013 at 9:14:26 pm
How do I accomplish the effect used in 1:05 of this video:
Is there a specific plugin I need to use?
John Cuevas
Re: Specific Video Breakup Effect
on Nov 10, 2013 at 1:49:49 pm
Set up your two pieces of video where you want your cut. Add an adjustment layer and add the effect Distort>Transform and set the scale to 150. Now just add a couple of moving masks to the adjustment layer over about 1 second duration. Here's a quick example project I made demonstrating the technique:
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Steve Kline
on Apr 5, 2015 at 2:35:51 am
This looks like a plugin called twitch - it's a very fast way too achieve this effect with out a large amount of manual key framing and has decent flexibility in settings
© 2018 All Rights Reserved
