Stamp Tool Crashes
Angel Nieves
Stamp Tool Crashes
on Nov 5, 2013 at 10:52:43 pm
Using AE CS6. My stamp tool is crashing after painting a few frames. I was able to use it successfully before but then it started freezing, and haven't been able to use the stamp tool since. Any ideas anyone? Can't find anything online.
mathew fuller
Re: Stamp Tool Crashes
on Nov 5, 2013 at 11:20:27 pm
Depending on your AE version... try switching from Open GL to Adaptive resolution. It's the little lightning bolt at the bottom of your comp view.
My Work:
http://www.morecompletefx.com
Angel Nieves
on Nov 6, 2013 at 12:24:29 am
It was already on Adaptive Resolution, but thanks for replying.
mathew fuller
on Nov 6, 2013 at 12:33:40 am
Then try open gl.
My Work:
Angel Nieves
on Nov 6, 2013 at 12:57:07 am
Don't have that in CS6. I don't think it has anything to do with that. As I've done more research I realized that CS6 is 64 bit. Before I was working in 32 bit. I don't have enough RAM on my laptop. That's probably what's freezing it up. I may have to reinstall CS4 in order to use the stamp tool. Again, thanks for trying.
