Arrows... good old arrows... questions about large arrows
Adam Lewen
on Oct 31, 2013 at 4:45:39 pm
Hi again!
I have a network of thick arrows I need to animate.
I know of 2 ways to accomplish the task.
1 - Generate a stroke (where I can copy mask path to the Head's position...) it's a great way, but I need thicker strokes than the maximum 50.
2 - Using a shape's layer stroke where I animate the stroke with "trim paths" also a great way, but here I am having trouble with aligning the Head's position...
So before I try to mesh the 2 methods, I thought asking here I might find a solution... I am sure this was asked many times, I just couldn't find an answer.
If the stroke was smaller than 50 I would defiantly go in this way
http://www.monologue.gr/tutorials/an-animated-arrow-tutorial-to-rule-them-a...
Also, trying to duplicate the stroke and scaling or shifting it a bit is not working great when I have curves...And I have many.
Any help is greatly appreciated!
Adam
Tudor "Ted" Jelescu
Re: Arrows... good old arrows... questions about large arrows
on Oct 31, 2013 at 6:21:19 pm
Maybe using Zaxwerks 3d serpentine may be easier.
http://zaxwerks.com/3dserpentine/
Tudor "Ted" Jelescu
Senior VFX Artist
Adam Lewen
on Nov 1, 2013 at 5:26:25 pm
Hi Tudor, thanks for the reply.
It's a very 2D flat design, so I was really hoping something in the stroke area...But i'll defenitly give it a shot! Hope I can render with a trail version...
Tudor "Ted" Jelescu
on Nov 1, 2013 at 6:43:23 pm
You can play with lights for a flat look or just use the alpha to comp white.
Tudor "Ted" Jelescu
Senior VFX Artist
