Motion graphic 50i
John Mark
Motion graphic 50i
on Oct 31, 2013 at 11:24:21 am
This graphic used in this clip -
runs smoothly when watching the channel "7" on TV. Its smooth interlaced motion I assume at 25i 50 fields per second.How can I make this same graphic as smooth as it is on TV while is still comes in fast and "hard"?
Or are they using a special hardware or software to overlay at 50fps?
Thanks guys!
Tero Ahlfors
Re: Motion graphic 50i
on Oct 31, 2013 at 1:43:17 pm
How many times are you going to ask this same question? The animation looks smooth because the keyframes are probably eased in and/or out and not straightforward linear keyframes.
Also one could try enabling motion blur.
© 2018 All Rights Reserved
