Moving the whole timeline
zoe griffiths
on Oct 30, 2013 at 6:49:08 am
Hello all,
Hoping someone might be able to help me with some expert AE advise...
I'm working on a 30 second animation for a corporate client. It has to be 30 seconds on the noise, but I'm coming out at just over.
I'm watching the edit through and there are points I could nick out a second here or there, but I have no idea how to do that other than re-jigging every layer.
Is there a simple, easy way of cutting out time that will shuffle down all the layers without me having to individually move each layer?
I'm sure it must be easy, but I can't work it out. Any help would be really appreciated!!
Oh and I'm working on cs6.
Thanks so much,
John Cuevas
Re: Moving the whole timeline
on Oct 30, 2013 at 11:42:26 am
You precomp the entire timeline, then just use "shift+cntl+d" to split your layers, cut out/delete what you don't need.
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
© 2018 All Rights Reserved
