Snapping layer & keyframes to nearest whole frame?
Navarro Parker
on Oct 29, 2013 at 11:25:46 pm
Is there a script that will snap my layers and keyframes to the nearest whole frame/time unit?
I had a bunch of comps at 24 fps that I changed to 23.976 (via rd_CompSetter). But now some in-points and keyframes are lying on fractional frames which is causing problems (layers slip in time a frame so what I see in the comp window and what I get in the final render are not the same).
Is there an automated way to get layers to snap to the nearest whole frame?
Todd Kopriva
Re: Snapping layer & keyframes to nearest whole frame?
on Oct 30, 2013 at 1:40:32 am
Yep.
Jeff, my coworker, just released this and is looking for feedback:
http://www.redefinery.com/ae/view.php?item=rd_SnapDecisions
After Effects team blog
Navarro Parker
on Oct 30, 2013 at 4:57:34 pm
Perfect. Exactly what I was looking for! Thank you!
