Trapcode Particular // Emitter Type: Layer // Problem
Hans Oberholz
on Oct 28, 2013 at 7:32:02 pm
hey guys,
I am having problems with particular. I am trying to use a layer for emitter. i tried to follow tutorials and also got info directly from trapcode(http://www.trapcode-content.com/help/particular/layer_emitter.html).
Nothing works! When i set the emitter type to layer, the particles just disappear(no matter what point in timeline). The plugin blocks me from choosing a layer for emitting the particles (See picture)
Iam using the new After Effects CC. Andy Ideas? I Need help quickly!
Thanks a lot!
Roland R. Kahlenberg
Re: Trapcode Particular // Emitter Type: Layer // Problem
on Oct 28, 2013 at 7:43:45 pm
You've selected "Layer" as your Emitter Type BUT did you select the layer itself - you select a specific layer in the Layer Emitter property.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
Hans Oberholz
on Oct 28, 2013 at 7:49:18 pm
Sorry i just dont get it - where do i do that?
Hans Oberholz
on Oct 28, 2013 at 7:50:57 pm
shame on me - i found it! blessed are those who have a look
Hans Oberholz
on Oct 28, 2013 at 8:50:19 pm
NEW PROBLEM:
I use particular to create a 3D glow emitting from a circle shaped layer.
I figured out how to use the layer as emitter. So far..
I increased the particle size and the glow(using glow sphere particles) and use the circle as obscuration layer.
two problems appear: 1. though use the obscuration layer the particle glow "penetrates" the layer
2. In profile the particles sigficantly shine through the layer. is their a way to
avoid that? In CC Particle World i can set the visibility to "Show only above floor"
can i do that here as well?
on Oct 29, 2013 at 1:21:18 am
[Hans Oberholz] "1. though use the obscuration layer the particle glow "penetrates" the layer"
Use a variation of the obscuration/emitter layer that accurately obscures the particles within the required layer. Then use this layer as a matte (Track Matte) for the Particular layer.
I'm not sure what the issue is with (2) that you described. Perhaps a few screen captures will be helpful.
HTH
RoRK
