Mask in pre compose leyer
Bruno Pacheco
on Oct 26, 2013 at 7:35:49 pm
Why dosenĀ“t work a mask (rest mode) in a pre composed leyer (with 2 leyers in luma track mode and a black solid)?.
John Cuevas
Re: Mask in pre compose leyer
on Oct 26, 2013 at 8:38:19 pm
I gather English probably isn't your first language, so you are going to need to try and explain that a little better, it doesn't really make much sense.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Bruno Pacheco
on Oct 26, 2013 at 8:51:41 pm
I was doing the 140 video copilotĀ“s tutorial.In minute 11:53 Adrew Kramer used a fast blur to correct the tracking error in the precomposed layer "illumination map": I tried using a mask to better correct the tracking error but subtract mode mask areas not covered desired ... I wonder why that happens?
mathew fuller
on Oct 26, 2013 at 9:43:14 pm
Subtract masks have to be stacked underneath add masks.
My Work:
http://www.morecompletefx.com
mathew fuller
on Oct 26, 2013 at 8:46:29 pm
I don't really understand your question either. So I'll give it a try.
Maybe you need to press the "continuously rasterize" button on your pre-comp.
It's the button in the red box on the left side of this image.
http://www.crookedgremlins.com/wp-content/uploads/2008/09/crandmb.png
My Work:
