export to 32:9
Paco Fernandez
export to 32:9
on Oct 26, 2013 at 8:38:26 am
Hello, mi question is the next:
which is the best option to export quicktime quicktime h.264 in another
with dimensions of 3840 x 1920 (32:9) thanks in advance.
Roland R. Kahlenberg
Re: export to 32:9
on Oct 28, 2013 at 2:43:38 am
AME should be ideal if you're going to use one of Adobe's app.
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
Paco Fernandez
Re: export to 32:9
on Oct 28, 2013 at 8:56:14 am
I think I have not explained well. When I try to export a movie to quicktime with H.264 codec from after effects prevents me from formatting restrictions (maximum 2000 px) my movie is 3840 x 1080. It occurred to me export a sequence of pngs and then from quicktime QT export the output to H.264 and it works, the results are not very good (the film lacks contrast), by the way if I try to do the same from AME not work (restrictions format). I decided to try to climb the contrast of the movie before exporting a sequence of pngs. Do you think this is the best method? Thanks in advance and sorry for the extension
© 2018 All Rights Reserved
