My render quality (quicktime h.264) is very low quality
ali khoshdouni
on Oct 23, 2013 at 1:12:50 am
I installed adobe cc... in my after effects render panel.. i choose quicktime then set to h.264 in 12000 limit data rate .. my footage is 1080p direct from dslr. but exported footage is very very low quality!!!! 12,000 bit rate but low quality??????
Todd Kopriva
Re: My render quality (quicktime h.264) is very low quality
on Oct 23, 2013 at 1:44:57 am
Don't use the H.264 codec in a QuickTime container, and don't export H.264 files directly from After Effects. Neither of those things will give good results.
Send your composition to Adobe Media Encoder and use an encoding preset in Adobe Media Encoder to create an H.264 file.
After Effects team blog
ali khoshdouni
on Oct 23, 2013 at 2:23:27 am
Yep.. thanks.
I tried to use media encoder and it was pretty good compressed. Sometimes i use cineform 444 codec . but in adobe media encoder its not available. When i instal cineform its automiclly will be available in after effects. but not available in media encoder.. how can i use that in adobe media encoder?
