Looping graphic
Steve Pro
Looping graphic
on Oct 21, 2013 at 7:18:18 am
Hello Steve here,
I have graphics running at 1080i50 into my Broadcast switcher from Black Magic. My question is, how am I able to loop a graphic without it looking from the start, were is reopens?
Many thanks!
John Cuevas
Re: Looping graphic
on Oct 22, 2013 at 9:47:54 am
Depends on the graphic, can you get it to go back to it's starting point? Otherwise, every technique I know is a variation of just dissolving your graphic back to the beginning as fluidly as possible.
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
George Goodman
Re: Looping graphic
on Oct 24, 2013 at 9:02:03 pm
Use time remapping with the ping pong looping expression and set it so that it only bounces between 2 keyframes.
© 2018 All Rights Reserved
