DPX plus crash AE
Diego Stehle
DPX plus crash AE
on Oct 20, 2013 at 10:54:11 pm
Hello everyone,
Im trying to export a DPX Plus sequence form After Effects. I'm having trouble doing it, because every time I try to render, AE crashes and shuts down. I don't understand why this is happening since I already tried exporting in many different formats, even DPX Cineon works.
Any help would be very much appreciated.
Todd Kopriva
Re: DPX plus crash AE
on Oct 21, 2013 at 2:09:14 am
We need to know a lot more to help you. Please provide answers to the questions listed here:
"FAQ: What information should I provide when asking a question on this foru...
After Effects team blog
Conrad Olson
on Oct 21, 2013 at 4:41:01 pm
DPX doesn't support an alpha channel, so that might be your problem.
conradolson.com
Diego Stehle
on Oct 21, 2013 at 6:26:00 pm
Thanks for your reply Conrad.
From what I had understood, DPX Plus allows for 8, 10, 12 or 16 bit DPX files + Alpha within Ae.
Conrad Olson
on Oct 21, 2013 at 6:29:00 pm
I haven't heard of DPX Plus so you might be right. All I know is that Nuke lets you setup a DPX render with an alpha channel, but then it fails in render.
conradolson.com
G. Scott Scribner
on Nov 6, 2013 at 9:36:14 pm
Render in the command line. I have the same problem with AE's GUI.
Diego Stehle
on Nov 6, 2013 at 9:43:44 pm
AWESOME, I´LL LOOK INTO IT. HOPE IT WORKS. THANKS FOR YOUR REPLY
lgeorge
DPX plus in AE
on Nov 12, 2013 at 5:26:22 am
I need to use DPXPLUS this week. I have the zip download... what procedure did you use to plant the plug-in. My plug-in folder won't accept the file. Any other advice? I have 12 bit dpx stuff.
Todd Kopriva
Re: DPX plus in AE
on Nov 12, 2013 at 6:26:04 pm
If you have After Effects CC (12.0 or 12.1), you don't need to install anything additional.
See this:
http://blogs.adobe.com/aftereffects/2013/06/new-openexr-and-dpx-importers-f...
